boas comprei recentemente uma audi a4 b8 170 cv ano 2009.
comprei o cabo v12.12 e fiz o meu primeiro chek up.
agora preciso da vossa ajuda...
obrigado
Tuesday,01,October,2013,16:15:14:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8KXAA041168 License Plate:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8KXAA041168 Mileage: 178130km/110684miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H21 5073
Revision: 25H21---
Coding: 12194012232403080000
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022NP A02002
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 800FE6821BA38E1E143-80D5
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
5619 - ROD - Unknown Error Code
- 00 [032]
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AM HW: 8K0 907 379 AM
Component: ESP8 front H04 0100
Revision: -------- Serial number: --------------
Coding: 160D0C
VCID: 8407EA9207BB923E30B-80D1
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0321
Revision: 00002001
Coding: 030200
VCID: 8109E38618A987161BD-80D4
Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0171
Revision: A1000000 Serial number: 01220720090275
Coding: 34300000
VCID: 77FD0D5EC66D49A6A59-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000315292
Coding: 26005091403400010001000300001D0D001C07080401000100 0000
VCID: 3C77D272BFCBAAFE88B-8069
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200709 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD04CWT-
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4189A386D029C716DBD-8014
Crash sensor for side airbag; driver side:
Serial number: 6334MSME464036545
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME49716604B
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME533432322
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME38362F06L
Crash sensor for front airbag; driver side:
Serial number: 63732SME6233060CV
Crash sensor for front airbag; passenger side:
Serial number: 63832SME190D1922.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IGL00056
Coding: 000017
VCID: 3D71DF76A4D1A3F6BF5-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 D HW: 8K0 920 930 D
Component: KOMBIINSTR. H19 0253
Revision: 00100000 Serial number: BXP72DF79
Coding: 0F04100003000008000000
VCID: 2E53E83A79B7486E36F-807B
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E0970383F7
Coding: 00CF07
VCID: 52AB9CCA0D4F4C8E727-8007
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H14 0037
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000101549561
Coding: 011002204000410001
VCID: 479DBD9EF60DF926159-8012
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0120104987
Coding: 01000620203904400120020400000000
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 176820 km
Time Indication: 0
Date: 2013.12.07
Time: 17:06:33
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 176820 km
Time Indication: 0
Date: 2013.12.09
Time: 12:21:08
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000101548800
VCID: 4683B09AF107E02EEEF-8013
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000416567
Shop #: WSC 00000 000 00000
VCID: 3467FA52979B62BE40B-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 387FCE624BF386DE6C3-806D
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 207
Mileage: 177193 km
Time Indication: 0
Date: 2014.01.11
Time: 19:56:49
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341G1097607799
Coding: 010003020000000001
VCID: 1C3732F21F0BCAFE68B-8049
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 652 D HW: 8T1 035 652 D
Component: B-BN-EU H52 0048
Revision: -------- Serial number: 323GU097514491
Coding: 010100010006A1EC01000B0C000000030001
VCID: 3663C05A81E770AE7EF-8063
Subsystem 1 - Part No: 4G0 919 884 D
Component: EUR 2009/2010 5804
Subsystem 2 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
Address 62: Door, Rear Left (J38 Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101550709
Coding: 010002204000210001
VCID: 428BAC8ADD2FDC0EC27-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101550706
obrigado
Revision: 25H21---
3 Faults Found:
U1113 00 [032] - -
U1113 00 [032] - -
- 00 [032]
Coding: 160D0C
Revision: 00002001
Coding: 030200
Coding: 34300000
Coding: 00FD11
Coding: 000017
Coding: 00CF07
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 176820 km
Time Indication: 0
Date: 2013.12.07
Time: 17:06:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 176820 km
Time Indication: 0
Date: 2013.12.09
Time: 12:21:08
Coding: 0000004
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 207
Mileage: 177193 km
Time Indication: 0
Date: 2014.01.11
Time: 19:56:49
