600hp turbo s2k fully built gt35r erl in kentucky
  • Thread starter Thread starter marku
Make: Honda
Model : S2000
Year : 2000
Color : Silverstone
Body Mileage : 89,000
Engine Mileage :100 just had full rebuild from erl ring, bearing, oil pump etc
Modifications :
Engine:
stock head
Erl Bottom End with Darton Sleeves stock bore, CP Pistons calico coated top, skirts, CP Rings, and Crower Rods – 9.0:1 Final Compression Ratio
ACL calico coated race bearings
new oem oil pump
Rick's underdrive pulleys
innovativemounts Urethane Stiffness 95A Extreme
CARBONETIC triple disc clutch
AEM EMS with Uego
HKS Twin Power Ignition Amplifier
Lovefab mini-me Manifold
garret gt 35r .82 ex Turbo
Lovefab 3” Downpipe
Inline Pro 3” Exhaust
Tial 44mm Wastegate
hks Blow-Off Valve
rc 1200cc Injectors
AEM egt probe
AEM 5 Bar Map Sensor
AEM Fuel Pressure Regulator
Walboro 255 Fuel Pump
Hondata Intake Manifold Gasket
Koyo Radiator
neukin catch can
Tein hood shocks
Precision 750hp intercooler
odyssey battery PC680MJT put in trunk
Suspension:
Cusco subframe bracing
Megan coilovers
Inline Pro Differential Conversion Kit with Driveshaftshop Custom Driveshaft and Stage5 Axles
Nissan 300ZX Non-Turbo Differential
mickey thompson et street
Exterior:
Oem Front Lip
stock wheels
vis oem cf hood
vis cf trunk
oem black hardtop it has only the hardtop= no soft top at all
Interior:
Cusco 4 Point Roll Cage
Aem oil pressure gauge
Aem true boost Gauge
AEM serial gauge
SOS 52mm dual gauge pod
