Ajuda com erros de airbag
Liguei pela primeira vez o vag-com na minha carrinha, e descobri agumas coisa más , varios erros de airbag os quais eu vou por em baixo, precisava de um electricista bom na zona da Maia que seja capaz de me resolver o problema visto que eu não entendo nada do assunto.
VCDS Version: Release 12.12.0
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 KD
Component: 1,9l R4 EDC G000SG 4897
Coding: 00002
Shop #: WSC 05314
VCID: 63C54907F1A06306E91-49D8
WVWZZZ3BZ4E294192 VWZ7Z0D9379028
1 Fault Found:
18044 - Powertrain Data Bus
P1636 - 35-10 - Missing Message from Airbag Controller - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 12345
VCID: 2541171FBF14DD36C75-5072
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
VCID: 29591B2FD30CF956E3D-5072
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0R AIRBAG VW51 04 0008
Coding: 12370
Shop #: WSC 05311
VCID: 23450907B1202306A91-4A3A
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
00588 - Airbag Igniter; Driver Side (N95)
29-00 - Short to Ground
01221 - Crash Sensor Side Airbag; Driver Side (G179)
30-00 - Open or Short to Plus
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 849 A
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 21115
Shop #: WSC 00222
VCID: 26431013C212D62ECEF-5000
1 Fault Found:
01321 - Control Module for Airbags (J234)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0EFB64BB056489EE43-5072
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 7X Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 3663C05312B2A6AE7EF-4A3A
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
27-10 - Implausible Signal - Intermittent
Mas tens algumas luz acesa ?
Apagaste os erros e eles voltam ?
Aí é que está não acende nenhuma luz no quadrante, porque provavelmente a desligaram para que eu não soubesse, o carro já veio assim de quem o comprei de certeza.
Apaguei os erros e voltei a fazer scan e eles voltaram a aparecer.
Tenta perceber se taparam o aviso de airbag no quadrante e podes fazer um Test ás luzes do quadrante e assim vês se elas trabalham.
Mas a luz acende e apaga ao ligar a chave?
Não nem a do EPC supostamente também devia acender certo ?
ui ui... provavelmente foste aldrabado! compraste o carro a muito tempo?
Sim faz agora 2 anos mas só agora abri os olhos devia ter visto logo quando o comprei.
Quando faço teste ao painel de instrumentos ele só faz teste a algumas luzes, a do airbag e EPC não faz' também não faz ao ABS e ao ESP mas estão a funcionar porque acendem quando eu LIGO o carro.
A do EPC só se for carro a gasolina
Luz do Airbag basta ligar a ignição na 1 posição vês logo se funciona ou não...
bom o certo, é realmente tens um problema com os airbags, sô acho estranho, um erro dizer que não tem comunicação com o modulo de airbag, e depois aparecer erros relacionados com airbags, e sensores de airbag :S
o melhor que tens a fazer, é pores o carro nas mãos de um especialista em airbags...
É isso mesmo que ando a procura ja me fartei de andar nos foruns a ver se encontrava alguem especialista em airbags mas para já nada mas obrigado a todos pela preocupacao.
Abraco
Abraco
se fosses da zona centro sei quem te fazia isso, ai no Norte talvez também te consiga dizer quem o faz, segue PM..
