[ajuda] Erros vagcom - b5
  • Thread starter Thread starter TCPT
oi ppl tenho estes erros nos engine alguem me pode ajudar a dizer o ke se passa ?
Sunday,07,October,2007,14:14:50:55371
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 028 906 021 F
Component and/or Version: 1,9l R4 EDC SG D3I
Software Coding: 00000
Work Shop Code: WSC 00000
4 Faults Found:
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
P1570 - 35-10 - - - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
Readiness: N/A
de x em kando sim kando a porcaria do codigo de chave pisca ... fico fulo com akilo kando kero bazar o raio do carro n pega ..
um dos erros é esse
e acusa intermitente pois so acusa as vezes
TCPT disse:
e o resto ? alguem pode arranjar os eskemas para localizar o fio do imobilizador ??
o resto ja tens que pagar ......... looooooooooooooooooooooooooooooooooooooooooooool
tu ate es um puto porreiro por isso toma la
n75 nas couves
00575 - Intake Manifold Pressure: Control Difference
Possible Symptoms
Reduced Power
Possible Causes
Solenoid Valve for Boost Pressure Control (N75) defective
Hoses incorrect connected, disconnected, blocked or leaking
Possible Solutions
Check Solenoid Valve for Boost Pressure Control (N75)
Check Hoses
65535
Possible Causes
Control Module housing leaky > Control Module wet
Wiring from/to Control Module faulty
Possible Solutions
Check/Clean Wiring from/to Control Module
Replace Control Module
Special Notes
This fault is NOT to be ignored when found in a major and/or critical system (Airbag, ABS etc.).
When stored in other systems (Radio etc.) the general suggestion is to ignore it unless you notice functional limitations.
Audi Airbag 6 & 7
Problem: A fault of the acceleration sensor may result in the above fault.
Solution: Replace Airbag control module and both acceleration sensors.
Audi Airbag 8
Problem: Due to under voltage the control module does not complete it's self test successfully.
Solution: Replace Airbag control module and install a under voltage protection relay for it.
Certain older TDI ECUs which have a vacuum line going to them
Problem: Vacuum line broken, either before ECU or inside ECU.
Solution: Inspect and repair vacuum lines to ECU and inside ECU.
ao fim de uma semana aki ficam os erros
Saturday,13,October,2007,12:34:39:55371
Address 01: Engine
2 Faults Found:
Readiness: N/A
isso quase de certeza que é a n75 e mau contacto no imobilizador .
mas aquele trabalhar ao vivo , parece que vai saltar um piston fora
OT que não resisto em comentar:
Pelo que li noutro Tópico, se apagares esses erros, o carro dá-te logo mais 15km/h em velocidade de ponta!
:green:
