Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 77933 146 84117
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
1 Fault Found
00532 - Supply Voltage B+
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Time Indication: 0
Freeze Frame:
Hex Value: 0x1200
Hex Value: 0x5302
Hex Value: 0x00FF
Hex Value: 0xFFA1
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 06325
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 11021
Shop #: WSC 65536
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M0014RXA
Coding: 0033622
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0004041
Shop #: WSC 05572 843 13298
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0400356
Coding: 0309217
Shop #: WSC 00000 785 00200
2 Faults Found
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:07
Freeze Frame:
Voltage: 12.70 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:02
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BS
Component: Komfortgerát TA7 3332
Coding: 23408
Shop #: WSC 12397
Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Part No: 8E0 941 329
Component: AFS-Modul links H01 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309217
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:07
Freeze Frame:
Voltage: 12.70 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:02
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802130432
Coding: 0000114
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 M HW: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Revision: 00000001 Serial number: 00000000434796
Coding: 0001811
Shop #: WSC 77933 150 84117
neljoe disse:Este ELFuracon não existe!
ELFuracon disse:Nos caso dos vidros electricos traseiros, estamos a falar no total de 4 fios (de cada porta) que devem ser ligados simplesmente a outros ja existentes e não é preciso ir ligar aos cabos das portas da frente.
1-Convenience CAN H
2-Convenience CAN L
JM disse:Não, não funciona, só memoriza os retrovisores os bancos não acerta.
Por acaso tenho a impressão que antes de andar a mexer com o vag-com os retrovisores também não memorizava, mas não tenho a certeza deste facto.
Sobre os bancos, será possível o módulo de conforto não saber da existência do banco do condutor ou vice-versa? e por esse facto não memorizar a posição.
ELFuracon disse:Não, se está tudo ok, essa questão não se coloca.
A memorização dos bancos tem de ser feita com o carro parado.
É questão de seguires os passos do manual.
