O que é isto?
Fiz um Vag-Com e deu-me isto.
Alguém opina?
VAG-COM Version: Release 607.3-UD
Saturday,18,October,2008,20:51:58
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN Number: XXXXXXXXXXXXXXXXX
Address 01: Engine
Part No: 038 906 019 AN
Component: 1,9l R4 EDC 0000SG 1301
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D58
Coding: 00043
Shop #: WSC 06435
Address 15: Airbags
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 00106
Shop #: WSC 06435
1 Fault Found:
01213 - Belt Tensioner Igniter; Rear Middle (N198)
32-10 - Resistance too High - Intermittent
Address 17: Instruments
Part No: 8D0 920 900 M
Component: KOMBI+WEGFAHRS. M73 D51
Coding: 00040
Shop #: WSC 00000
XXXXXXXXXXXXXXXXX AUZ5Z0Y5265047
Address 25: Immobilizer
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 14913
Shop #: WSC 06435
2 Faults Found:
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
End --------------------------------------------------------------------------------------------------
17965= ou tubo roto ou n 75
01213= pre tensor traseiro avariado ou activado
01367=tens uma fuga ou tives-te na tubagem do fecho central
00956= foi ultrapassado o limite de configuraçao de chaves ou seja nao podes fazer mais nenhuma copia
